  • 21
Message 1 of 42
2.4ghz wifi speed slloooowwww - Just joined Virgin
Hello Virgin Forum
Just joined Virgin 3 days ago (100m&phone) and looking for some help please as the Hub 3 wifi on 2.4ghz keeps dropping out whether right next to the hub or in another room.
5ghz wifi & ethernet connections are fine. Light stays white on router.
Currently between 16 to 18 devices connected, 4 ethernet, rest wifi.
Tried a few things, split the 2.4 & 5.0 networks, turned off optimisation and tried the different 2.4 channels of 11, 6 and 1. Restarted the router. Fault remains.
My assumption is there is an issue with the hub router and I've read other threads here that suggest the hub is really a bit pants.
So, do I need to contact VM as in 14 day cooling off period for some kind of redress? If so what are they likely to offer if anything?
Guessing I need to buy my own router or mesh. If so how can I deduce the area a mesh network will cover and how many nodes/repeaters are required please? Is it a buy it and try it sort of thing or can an area of coverage be worked out first?
Bungalow with garden office. Previously with Vodafone 36mb fibre and had full wifi through the house with the ISP provided modem/router without drop outs and one single channel wifi booster in the office with the pc connected to it via ethernet.
Any help and suggestions appreciate. Thanks 🙂
  • 14.98K
  • 1.14K
  • 1.87K
Message 2 of 42
Re: 2.4ghz wifi speed slloooowwww - Just joined Virgin
What actual speeds are you getting ?
  • 21
Message 3 of 42
was getting around 100mb on both 2.4 & 5.0 on Saturday when installed.
Now around 100mb on 5.0
2.4 drops to basically zero, then will be 20mb, then 50mb. Restart hub, might then be around 100mb for a bit, then drops again.
  • 14.98K
  • 1.14K
  • 1.87K
Message 4 of 42
May I advise you to download and install a Wi-Fi analyser to show if there are any foreign Wi-Fi broadcasts interfering with your own Wi-Fi signals. From there you can look at refining your own Wi-Fi broadcasts.
I use this one ...
WiFi Analyzer Premium - Apps on Google Play
wifi-2
  • 27.48K
  • 1.63K
  • 3.53K
Message 5 of 42
Yup. That’s what 2.4Ghz Wifi will do.
  • 21
Message 6 of 42
I use that exact wifi analyser app already, although a free version - thank you for the suggestion though
  • 14.98K
  • 1.14K
  • 1.87K
Message 7 of 42
Post screen shots for the 2.4GHz and 5GHz broadcasts and tell us which broadcasts are yours.
  • 21
Message 8 of 42
  • 21
Message 9 of 42
  • 21
Message 10 of 42
Tags (1)
