derekgb
  • 22
2. 4ghz connection
2.4ghz not connecting to the Internet but 5 ghz does. Router is superhub 2
Tags (1)
lotharmat
  • 2.54K
  • 189
  • 461
Trouble shooter
Re: 2. 4ghz connection
Might be worth a factory reset to see if it fixes it:
Make sure you can read all the default passwords on the base of the Hub before you do this
Unplug all ethernet cables
With the power on and the co-ax connected; press and hold the reset switch with a paperclip or sim removal tool for at least 60 seconds.
Allow 10 minutes to reboot, reset and stabilise
derekgb
  • 22
thanks for your info but a normal reset restored the service
Corey_C
  • 3.9K
  • 214
  • 323
Thanks for your reply and update, derekgb, glad to hear the reset restored your service.
Cheers,
Corey C
