Davesuperblue
2.4g issues on hub 4
I have just had a new hub 4 installed and now cannot connect my ring doorbell if fact I have tried splitting the 2.4 and 5 into separate channels but while the 5 shows clearly the 2.4 is not there any ideas as I have a lot of smart bulbs I would like to connect
gary_dexter
  • 30.24K
  • 1.87K
  • 4.02K
Re: 2.4g issues on hub 4
Disable the “smart” channel optimisation
Davesuperblue
Yes tried this but still no luck
  • 15.9K
  • 687
  • 1.56K
Its a known problem you have to get your own wireless router with 1Gb ports and use the hub in modem mode.
