Mike-xxx
Message 1 of 7
2.4g WiFi
Hi my 2.4g Wifi won't connect 5g is ok. Rebooted Hub 3. Still the same
jpeg1
  • 4.78K
  • 264
  • 772
Superstar
Message 2 of 7
Re: 2.4g WiFi
Do you have different SSIDs for the two bands?
Mike-xxx
Message 3 of 7
Re: 2.4g WiFi
Yes I do have 2 ssids. But still can't get 2.4g
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 4 of 7
Re: 2.4g WiFi
I'd try a full reset of the Hub!
Make sure you can read all the default passwords on the base of the Hub before you do this
Unplug all ethernet cables
With the power on and the co-ax connected; press and hold the reset switch with a paperclip or sim removal tool for at least 60 seconds.
Allow 10 minutes to reboot, reset and stabilise
Mike-xxx
Message 5 of 7
Re: 2.4g WiFi
Hi I have done a pinhole reset. And it has solved my problem. Thanks for all the help.
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 6 of 7
Re: 2.4g WiFi
Brilliant! - If it happens again - come back on here!
Worth keeping your eye on as if it keeps happening, it could be indicative of a WiFi failure of the Hub!
Corey_C
  • 3.96K
  • 216
  • 331
Message 7 of 7
Re: 2.4g WiFi
Thanks for your posts and updates, Mike-xxx,
Glad to hear that lotharmat's advice helped.  You can also find online help here: https://www.virginmedia.com/help/services-support/broadband
Cheers,
Corey C
