jonnyc1944
  • 8
2.4GHz not enabling so easily
I like to disable 2.4ghz here and there. When I turn it back on, it sometimes will do nothing after applying changes, no device sees the SSID. The router only sees the changes if I sit on the settings homepage (one after the password screen) for a second or two after enabling 2.4ghz and applying changes.
Is this some software/hardware bug?
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Re: 2.4GHz not enabling so easily
What hub is it?
Ayisha_B
  • 1.41K
  • 49
  • 133
Hi @jonnyc1944,
Welcome to our Forums and thanks for the post.
Sorry about the glitch there. How often does this happen? Have you tried factory resetting the router?
Ayisha_B
