zhoalex999
2.4 ghz signal is not working, impossible to enable it
Hello. My hub 4 is not working on 2.4 ghz signal. It is disabled and I can not enable it. It switches off automatically. I have rebooted hub and still no result. When I try to enable it in wireless settings It switches off. So I can't connect any device that is using 2.4 ghz signal. 5 ghz signal is working fine. Waiting for some advice to resolve this issue.
Tags (1)
lotharmat
  • 881
  • 61
  • 125
Well-informed
Re: 2.4 ghz signal is not working, impossible to enable it
Hiya,
Next thing to try is a pinhole reset!! = Make sure you have the default passwords for the hub!!!!
Disconnect any ethernet cables and press and hold the reset switch with a paperclip or Sim-Removal tool for at least 60 seconds
Give the hub about 10 minutes to re-sync properly and then try and see if you can re-enable the 2.4 network!
zhoalex999
Did it. Seems everything worked. Signal is back. Thanks for this advice. 👍
lotharmat
  • 881
  • 61
  • 125
Well-informed
Yay!!
Glad it worked!
