If you re-enable the 5GHz network what happens?
I am not sure how the Hub4 works - never seen one - so someone else needs to comment - but the standard advice for the Hub3 is to switch off channel optimisation/smart wifi and rename the SSID's of the two bands to separate them out. Dunno if you can do that on the Hub4.
Alternatively - put it into modem mode and use your own better quality equipment
