craigmc69
  • 15
Message 1 of 20
1G poor quality
moved to 1G from sky and wish I hadn't, the quality is atrocious, I doubt I can get out of the contract so will need to get it how I need it   My partner sits 6 feet away through a wall from Hub4 and her zoom calls are patchy and poor quality with connection issues, I got a pod last week from VM to try and give better coverage upstairs, marginal improvement from no signal to something but not great for watching TV as drops my sky Q box regularly
thinking about getting my own mesh so cal I please get recommends and if they work with hub4
last couple of days graphs but I don't understand them
thanks
craigmc69
  • 15
Message 2 of 20
Re: 1G poor quality
craigmc69
  • 15
Message 3 of 20
Re: 1G poor quality
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
Message 4 of 20
Re: 1G poor quality
thanks
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/45ca0ead2198bcb5e4c2510b3f2030b58562a8ba"><img alt="My Broadband Ping - my broadband CM" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/f603034a06702a0e83ac85e28fa37da0d76c61d1-19-01-2021][img]https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/f603034a06702a0e83ac85e28fa37da0d76c61d1-19-01-2021.png[/img][/url]
BQM doesn't look too bad:
Probably a good idea to access your HUB on http://192.168.0.1 navigate to 'Advanced Settings/Tools/Network Status' and copy/paste, as text, the 'Downstream', 'Upstream', and 'Network Log' tab data, in several posts, clicking 'Post' twice if an error occurs.
craigmc69
  • 15
Message 5 of 20
Re: 1G poor quality
3.0 Downstream channels
21470000008.440.4QAM2562
1139000000940.4QAM2561
31550000007.640.4QAM2563
41630000007.340.4QAM2564
51710000007.340.4QAM2565
61790000007.240.9QAM2566
71870000006.840.4QAM2567
81950000006.740.4QAM2568
92030000006.840.9QAM2569
102110000006.740.9QAM25610
112190000006.340.4QAM25611
12227000000640.9QAM25612
13235000000640.4QAM25613
142430000005.640.4QAM25614
152510000004.840.4QAM25615
162590000005.140.4QAM25616
17267000000640.4QAM25617
182750000006.640.4QAM25618
192830000006.340.4QAM25619
20291000000640.4QAM25620
212990000005.340.9QAM25621
223070000005.640.4QAM25622
233150000005.640.4QAM25623
24323000000640.4QAM25624
253630000005.640.9QAM25625
263710000004.940.9QAM25626
273790000004.240.4QAM25627
283870000004.140.4QAM25628
293950000004.240.4QAM25629
304030000004.240.4QAM25630
314110000004.540.9QAM25631
2Locked40.36628700
1Locked40.36628700
3Locked40.36628700
4Locked40.36628700
5Locked40.36628700
6Locked40.94620900
7Locked40.36628700
8Locked40.36628700
9Locked40.94620900
10Locked40.94620900
11Locked40.36628700
12Locked40.94620900
13Locked40.36628700
14Locked40.36628700
15Locked40.36628700
16Locked40.36628700
17Locked40.36628700
18Locked40.36628700
19Locked40.36628700
20Locked40.36628700
21Locked40.94620900
22Locked40.36628700
23Locked40.36628700
24Locked40.36628700
25Locked40.94620900
26Locked40.94620900
27Locked40.36628700
28Locked40.36628700
29Locked40.36628700
30Locked40.36628700
31Locked40.94620900
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
159964K1880QAM4096759
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked445.3398990
craigmc69
  • 15
Message 6 of 20
Re: 1G poor quality
3.0 Upstream channels
15370000038.55120 KSym/sec64QAM2
23260000035.85120 KSym/sec64QAM5
33940000036.35120 KSym/sec64QAM4
44620000037.35120 KSym/sec64QAM3
craigmc69
  • 15
Message 7 of 20
Re: 1G poor quality
Mon 21/12/2020 14:32:386CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 23/12/2020 02:52:403No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 23/12/2020 02:53:206CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 24/12/2020 19:19:284DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 24/12/2020 19:19:286DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 25/12/2020 09:52:486CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 26/12/2020 15:06:553No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 26/12/2020 15:13:296CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 26/12/2020 20:19:053No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 26/12/2020 20:26:536CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 28/12/2020 07:09:254DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 28/12/2020 07:09:256DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 28/12/2020 07:11:066CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/12/2020 10:43:063No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 30/12/2020 00:40:176CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 31/12/2020 19:09:254DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 31/12/2020 19:09:256DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 31/12/2020 20:35:086CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 04/01/2021 06:25:023No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 04/01/2021 07:09:254DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 04/01/2021 07:09:256DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 04/01/2021 11:57:016CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 06/01/2021 05:54:483No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 07/01/2021 14:24:073SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 07/01/2021 14:24:125Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 07/01/2021 14:25:013Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
Message 8 of 20
Re: 1G poor quality
HUB stats are good, power levels on the downstream a touch high but in spec.
So it could be down to hardware (The HUB).
Are your wired devices behaving? What do you get when running the below speed test?
https://samknows.com/realspeed/
gary_dexter
  • 28.91K
  • 1.77K
  • 3.78K
Message 9 of 20
Re: 1G poor quality
Nothing wrong there at all.
What are wired speeds and connectivity like?
craigmc69
  • 15
Message 10 of 20
Re: 1G poor quality
this is wifi about 8 feet through a wall from hub
