  • 45
  • 13
Dialled in
Message 1 of 7
Cable on outside wall needs moving and probably lengthening (potential repull?)
Hello
We are going to have some disability access work done very soon and the current step access to our front door has the Virgin media cable running around the steps. The existing access and steps are to be demolished and the builder has advised us to have the cable rerouted up and over the front door to our house.
How do I get this arranged as the cable needs to be rerouted as soon as possible. We cannot be without our Virgin media services as they are very necessary to us.
Thank you and kind Regards
  • 15.03K
  • 1.65K
  • 3.42K
Message 2 of 7
Re: Cable on outside wall needs moving and probably lengthening (potential repull?)
You can arrange this via the faults department on the usual number. As it is a non-fault related callout there is a standard charge of £99 for the work.
Be aware that a repull is likely to take several weeks. The cable can be jointed, but this is not ideal.
VIP pack with VIVID 350. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
  • 45
  • 13
Dialled in
Message 3 of 7
The work is being done through a disabled facilities grant, I can’t afford £99 for something that’s not our fault so I may have to go to Sky as we already have a dish installed. Thanks for your advice though.
  • 45
  • 13
Dialled in
Message 4 of 7
Does the £99 go on to the next bill? Because it’s for disability reasons would Virgin Media still charge us £99? If it wasn’t for disability reasons we would not have to move our cable, it’s been in the same place for four and a half years but has to be moved through no fault of ours.
  • 1.1K
  • 58
  • 120
Message 5 of 7
Hi Odin5, thanks for posting.
I would like to look into your issue a little further.  To enable me to do so, I am going to send you a private message. Please look out for the purple envelope in the top right of the screen.
Lee_R
  • 45
  • 13
Dialled in
Message 6 of 7
Is there a moderator who can help me with this and book an engineer for me please?
  • 1.1K
  • 58
  • 120
Message 7 of 7
Odin5
I have sent you a private message, if you could please respond and we can take it from there? 🙂
Lee_R
