switch to fibre phone
janeboxerdog
My cordless phones do not work since switch to fibre, I think I need an engineer
1 REPLY 1
Carley_S
Hi @janeboxerdog
Welcome back to the community forums
Sorry to hear that your phones are not working since the switchover.
Have you received the adapter through the post and connected this into the TEL 1 port at the back of your router with your landline then connected into the adapter rather than the master/extension socket?
Once this is all set up, please also reboot the router.
Let me know if you have and if this set up has worked in resolving this for you after the reboot.
Here to help 🙂
Virgin Media Forums Agent
Carley
