johnny64
  • 10
Message 1 of 5
no dial tone and crackling sound?
hi had no probs weekend called out received calls, today no dial tone and just crackling,phone will ring if someone calls  but when press to receive pick just noise crackling?,done virgin test no fault found?,tried unplugging wall socket,no good, tried book engineer come out as I'm pensioner need phone!,went through sequence book but when I press confirm nothing happens so I don't know if anyone's coming tomorrow 4-7 pm what a stress hope someone can help me please.
Jodi_S
  • 1.78K
  • 105
  • 182
Message 2 of 5
Re: no dial tone and crackling sound?
Hi johnny64,
Welcome to our community and thanks for posting. Sorry to hear that you have not working landline currently, we understand the frustration caused when this stops working.
Can we ask if you have tried another handset in the master socket? Also if you have any extension please remove these and try with just one handset plugged in.
Please can you let us know when you have tried the above so we can assist you further.
Kind regards Jodi
johnny64
  • 10
Message 3 of 5
no dial tone crackling sound reply jodi
hi Jodi thanks reply,yes I tried neighbours phone in wall absolutely nothing completely dead nothing no sound at all!
still have same problem today phoned virgin have engineer coming tomorrow 12-4 ,I had bad crackling on line over a year ago it fixed after two attempts good service from virgin and quick,hopefully resolved.
cheers
SCA1972
  • 5.79K
  • 654
  • 1.94K
Message 4 of 5
Re: no dial tone crackling sound reply jodi
@johnny64 Please don't create multiple threads for the same issue it is against the forum rules.  I have merged your threads.
______________________
Scott
My setup: V6 TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
HowardML
  • 12.28K
  • 1.43K
  • 5.73K
Message 5 of 5
Now I see what your problem is about replying. You are creating multiple threads. Just locate your original thread and keep to that one or it gets terribly confusing. OK you haven't been here before but that idea should be obvious. You keep all your letters to one person together at home. Same thing here. If you are not sure where your thread is or want to find it quickly then click on your name or image when you login or at any other time and then "My profile". That will always give you a list of all your posts
