on 01-06-2023 17:26
Hi I need help please I am unable to make or receive calls on my landline. How do I fix this problem
on 01-06-2023 17:52
Hi @NanaBx4
Sorry to hear your landline isn't working.
There's no issues from the system check done, please could you confirm that your landline is plugged into the telephone port one on the router?
Best wishes,
on 01-06-2023 18:08
Nothing has changed The technician set it up
on 01-06-2023 18:13
Thanks for coming back to me. I appreciate that but just could you confirm the above about the telephone being plugged into telephone port one on the router?
Best,
on 01-06-2023 18:53
Yes it is plugged into port 1 on the router
on 01-06-2023 18:55
Thank you for confirming 🙂
Please can you unplug it for me, then unplug the router itself. Leave for two minutes, before replugging both in. Let me know if that fixes it.
Best,
