wizzard93
  • 56
incoming calls drop out after about 20 seconds
Any incoming calls drop out between 18 and 23 seconds after connecting
There are no issues with calls going out
This has only started to happen since the end of last week
Phone is connected to Hub 4 and has call blocking feature but calls in are being made from approved numbers
Kain_W
  • 3.7K
  • 102
  • 263
Re: incoming calls drop out after about 20 seconds
Hi wizzard93,
Thanks for your post and welcome back to the community!
Sorry for any issues caused with the landline, for clarification have you performed a factory reset regarding this?
If so let us know and I'll advise further.
Kain
wizzard93
  • 56
Hi Kain
Thanks for the prompt reply.
Yes I have done a reset on the phone and base unit
Ayisha_B
  • 4.44K
  • 172
  • 395
Hi @wizzard93,
As your landline is connected via the hub, I can see there is a 48 day uptime. Can you reboot the hub and let me know if the issue persists?
It would also be worth checking there's not any loose connecting cables and everything is finger tight.
Ayisha_B
wizzard93
  • 56
Thanks Ayisha that seems to have sorted it
Martin_N
  • 8.87K
  • 371
  • 536
We're glad to hear that is sorted for you.
^Martin
