how do i order new hub for fibre phone
nigelkirkman
I need to order a new hub for fibre phone but there is no choice on virgin media 150
1 REPLY 1
Kath_F
Hi nigelkirkman,
I'm sorry to hear you've had issues with getting a new hub to allow you to switch to the new phone system. This is something we can certainly check for you but in order to do that I will need to confirm some information with you to pass security.
I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
Kath_F
