on 28-04-2023 18:29
There seems to be no way of arranging a connection between fibre and my my telephone network. 150 gives no no option please help.
Answered! Go to Answer
on 28-04-2023 23:30
If you want to use existing phone sockets via the connection from the VM hub, once you are 'switched', then VM should make those modifications for you free of charge as part of the switchover process. This is often arranged as a follow-up visit, post-switchover, as the old incoming line is disconnected from the master socket to prevent the new connection from the VM hub being fed back out into the street.
VM forum staff won't usually reply here in 'Tech Chatter'. A moderator or forum VIP may move your topic to 'Home Phone' where it will get a reply from VM staff.
Default cut/paste answer to this type of query is ...
Ask VM (via the VM forum team on here) to modify your home phone wiring so you can use your existing landline extension sockets via the phone connection from the VM hub.
VM should offer to do this free of charge for you as part of the switchover process.
Make sure they make modifications to your phone wiring so you can keep each piece of equipment in the same place (rather than the offer which sometimes crops up on here to move the hub to a different location)
Refer here
https://www.virginmedia.com/help/landline/switchover
Do I need to book a technician visit?
You’ll need to book a free technician visit if...
on 28-04-2023 22:34
@GoodGrief wrote:There seems to be no way of arranging a connection between fibre and my my telephone network. 150 gives no no option please help.
Your post does not give too much info as to what it is you are after.
Do you mean that your VM landline is now connected from the back of the VM hub and you want to enable telephone wall sockets around your home to work from the hub's phone connection?
on 28-04-2023 23:23
fibre phone is not enabled yet, have been supplied with an adapter in readyness for the great day. The phones are remote from the hub so the adapter is useless.
on 28-04-2023 23:30
Refer here
on 29-04-2023 08:19
Hi there @GoodGrief 👋 Welcome to our forum and thanks for your post 😊
Sorry to see you've not been able to arrange having an extension installed for your phone line. I'll certainly be happy to help arrange this for you. I'll send you a PM to confirm your details so this can be done.
Nathan
on 01-05-2023 11:11
Thanks for chatting with me via PM @GoodGrief 😊 I'm glad I have been able to help you get an engineer arranged.
Please let me know how this visit goes, if you need anything further, We'll be happy to assist.
Nathan
