lyndac18
dialled numbers
wheres the list of what numbers you have phoned
DJ_Shadow1966
  • 7.13K
  • 1.36K
  • 2.02K
Re: dialled numbers
Hello
VM will only list chargeable calls over your threshold for an itemized bill have a look at https://my.virginmedia.com/my-bills/index under your phone number on the bill section will show the calls made but only if chargeable any call made under a calling plan will not be shown.
Regards Mike
