robdian
Message 1 of 12
cannot receive incoming calls after moving to Virgin broadband okay on Sky.
We moved from Sky to Virgin Broadband 3 weeks ago and have been unable to receive incoming calls since, the engineer that install the system said it will take 24 hours.
I have rang 150 several times and also spoke to their technicians who said it was a porting problem from which could be the previous supplier not transferring our old telephone number, it has now been 3 weeks and still no incoming calls.
I have tried disconnecting my phone and ring the line and this works, also I can ring the line and plug in my phone and it works as normal until you ring again and it reverts back to one internal ring on the phone I'm using and then hangs up.
My phone is a B&O Beocom 6000
Any help as don't want to change my phone when it works on BT/Sky
David_Pn
  • 1.06K
  • 38
  • 55
Message 2 of 12
Re: cannot receive incoming calls after moving to Virgin broadband okay on Sky.
Hi robdian
Welcome to our community forum pages and thank you for posting.
We are sorry to hear that you have been unable to receive calls since installation.
We appreciate that this is very frustrating and not a good start to your time with us.
We'd like to take a look at this on here for you.
We'll send you a private message in a moment to confirm some details.
Thank you.
David_Pn
Need help changing SIM card? Find out more about activating your 4G ready SIM. 4G SIM Swap Help
Wes1fran
Message 3 of 12
I am having the same problem - I changed from Sky to Virgin Media last Tuesday & I cannot get incoming calls? I have a B&O phone?
robdian
Message 4 of 12
The virgin engineer that came a year after I had the line installed admitted that they have no fix for this issue.
i have searched google for fixes without any luck.
Lisa_CC
  • 3.79K
  • 232
  • 371
Moderator
Moderator
Message 5 of 12
Hi Robdian,
I've had a look at your details and can see that agents and the Telephony Department has already looked at your number issue last year. They contacted the Operator who owns the number who said that the number was ported to us. However I'm unsure whether they checked their switch to be sure. Can you tell me what type of calls are not being received?
Can you test to see whether Virgin Media landline numbers can get through and whether BT numbers (or a different operator) and mobile numbers can get through?
Lisa
Lisa_CC
  • 3.79K
  • 232
  • 371
Moderator
Moderator
Message 6 of 12
Hi Wes1fran,
Sorry to hear you're experiencing issues after moving to us from Sky. Can I ask whether the landline in question is the one on your account or are you referring to a different number that you had with Sky? If you log into your online cable account, you will be able to see your Virgin Media landline number. Can you also tell us whether you can make outbound calls and is there a dial tone? Please give us more information so we can help.
Lisa
Wes1fran
Message 7 of 12
Hi Lisa
yes it’s the same number we had with Sky. We can dial out & have a dialling tone. When it was first installed if anyone rang an answer phone came on & people could leave messages. Now there is nothing when people ring the line just makes a beeping noise to the person making the call then goes dead. The phone has never rang since we changed to Virgin.
Gareth_L
  • 5.72K
  • 343
  • 611
Message 8 of 12
Hello Wes1fran,
I can see we have had an engineer out to check this
Looking into a suggestion was made to see if the handsets you have are compatible with our service.
Have you tried an alternative handset yet
Gareth_L
Wes1fran
Message 9 of 12
  1. Hi
  2. no I haven’t yet but also my phone has stopped taking messages since the engineer came Saturday. I was at least able to pick my messages up but that isn’t working now. I can still dial out!
Gareth_L
  • 5.72K
  • 343
  • 611
Message 10 of 12
Hello Wes1fran
Thanks for your reply
If you can try an alternative handset that would be much appreciated
Gareth_L
