Gwen1
caller id not working after engineer visits and cable pull
my caller id  has stopped working after I had 2 different engineer visits and a cable pull. this is ongoing since 22nd Feb
japitts
  • 10.54K
  • 1.48K
  • 2.12K
Re: caller id not working after engineer visits and cable pull
@Gwen1
I've moved this post to the landline support board where it's more likely to get a staff response.
I'd have thought CLI was a core-network function and I'm not quite sure why a re-pull would be necessary to troubleshoot that of all things, but all the same.
Gwen1
thank you, appreciate that, engineers visits were for noise on the line, first one changed over at the box, noise still there and caller id stopped working, 2nd engineer said fault was not in the house or the box so was in cable, hence cable pull, noise still there and still no caller id. not overly worried about noise now but really need caller id fixed.
Ayisha_B
  • 681
  • 19
  • 68
Hi @Gwen1,
Welcome to our Community Forums and thanks for posting.
Really sorry to hear you are having issues with the Caller Display not working.
We have updated this for you our end so this should be working again now. Please can you check for me and let me know?
Ayisha_B
Gwen1
brilliant, thank you so much, that seems to be the problem sorted, well pleased.
Ayisha_B
  • 681
  • 19
  • 68
Happy to help @Gwen1
So pleased that's sorted now 🙂
Don't hesitate to pop back on here should you have any other issues.
Ayisha_B
