on 22-12-2022 12:50
Hi all , I have just switched to virgin fibre for my land-line, I can call out but cannot receive incoming calls, any help would be appreciated.
Answered! Go to Answer
on 22-12-2022 13:08
It happened as soon as I connected to the hub, its a new telephone, I can make out going calls but when you try to ring our home phone you only get a continuous tone .
on 22-12-2022 12:56
Hi johnboy55,
Thank you for your post!
Sorry to hear of the issues you're having here - is this something that has just happened today, in terms of the change? Is your landline now connected to your hub?
Cheers,
Ryan.
on 22-12-2022 13:08
on 22-12-2022 13:30
Thank you for letting me know.
What I will do is pop you over a private message so I can take a look into this for you.
Cheers,
Ryan.
