I joined Virgin on 27th October 2020 and requested my Sky Landline no. to be ported over. I kept my account open with Sky and the number successfully ported over a few weeks later, I could receive/make calls and the number showed on my virgin account.
However, it came to my attention on 17th December that my number that had ported over from Sky had been randomly changed without my knowledge. I called up customer service the same day who said they will return my number and need to re-request the port which could take up to a few weeks. This didn't happen so I called CS on the 14th January 2021, yet again, I was told they are going to re-submit the port and this time they text me confirming the port will happen on 26th January 2021. My number didn't come back on the promised day so I called back on 27th and was put through to customer relations, apparently, who conveniently told me they can see on my account that a port is set to go through on the 29th Jan 2021, which hasn't happened.
As you can imagine this is extremely frustrating as it was ported in successfully and I'm confused as to how my landline number has all of a sudden been changed by you guys. I'm questioning whether trying to port the number at this stage is even going to work? It was already successfully ported and Sky closed my account after you guys took the number so there is nothing to port as it successfully migrated to Virgin.
I really need this to be resolved so I can have my original number that I ported over, I have elderly relatives who only use landlines to contact us and as you can imagine in these times it is imperative I can be contacted in emergencies. You guys have changed my number I've had for 25 years without my knowledge, this needs to fixed ASAP as I have now had this service for 3 months without being contactable.
Many thanks
