Forest_1
Shift VM underground cable
I’ve been trying to get hold off VM for over an hour 🙈 not sure if anyone can help or advise me. I need to shift VM cable from one part of my garden to another part, whenever i ring through only option seems to be faults and i cannot speak to a anyone to give me advice. Who do i speak to regarding getting  VM cable move/relocated, or do i have to report as telephone or broadband fault to get an engineer out?
Thanks in advance
-tony-
  • 16.52K
  • 1.31K
  • 3.9K
Re: Shift VM underground cable
wait for VM to pick up the tread - they should be able to sort something - non fault call outs are £99 not sure if this will come under that charge or some other charge as it may need a repull
____________________
Tony
