Oldun
  • 24
Setting up landline via Hub 3 box
Today my hardware was upgraded to a Hub 3 and a V6 box. My broadband speed is now up to 200. My download speeds went form 5 mbps to 150 and my upload speeds from 12 to 20. My ping went from 50/100 to around 5-10 ms. Before, catch-up, if it every worked, suffered from incessant buffering. Now if appears to be quite fast and the signal no longer breaks up.
Due to the inconvenient placing of my landline phone sockets I wish to use the Hub 3 as the connection point for my phones.
Physically moving the phones is not a problem.
What do I need to do to get the system to recognize my phone connection via the Hub 3?
Anonymous
Not applicable
Re: Setting up landline via Hub 3 box
When you access your HUB using http://192.168.0.1 and login what does the 'Telephony' section say on the main page?
Oldun
  • 24
Thanks for the quick and helpful reply.
The router webpage tells me that the telephone is not enabled.
BenMcr
  • 21.44K
  • 2.34K
  • 4.3K
You can't self swap from a separate landline to Hub based one at the moment. That's down to Virgin Media to arrange.
So if you have a separately provisioned landline you have to continue to use that unless you're advised differently by Virgin Media.
