Boneywoney
  • 49
Restrict calls from home phone
I would like to put a restriction on calls from my Virgin home phone in the same way I have a restriction on my Virgin Mobile account.  I am overseas at the moment so calling Virgin is out of the question and I can't find an email address where I could contact Virgin.  Can anyone advise, many thanks.
DJ_Shadow1966
  • 6.85K
  • 1.31K
  • 1.89K
Re: Restrict calls from home phone
Hello
First of all I am afraid that Virginmedia do not offer support by email.
What do you mean you want to restrict calls on your landline, are you trying too stop all calls, international etc ?
Have a look at https://www.virginmedia.com/snippets/help/call-barring this is a subscription service, and would have to be initiated from the actual phone, once you have subscribed to it. If you look at https://store.virginmedia.com/content/dam/eSales/Downloads/Phone%20User%20Guide.pdf it tells yoou what you can do and which calls can be barred.
Regards Mike
Boneywoney
  • 49
Thank you for the information.  I was hoping to stop all calls from my home phone bar emergency numbers because I'm concerned my line may be abused, I wanted to protect myself.  I can't set up a bar from the phone as I'm on the other side of the world.  It doesn't really surprise me as Virgin are virtually impossible to contact unless one wants to upgrade in some way, I've been with them long enough to how unhelpful they can be and why they don't offer email as a method of contact.  Thanks anyway.
Gareth_L
  • 6.1K
  • 375
  • 659
Hello Boneywoney
Thanks for your post
I have checked few things from here and we can add Call barring
The only downside is that its Customer operated
Meaning you would have to activate this by a combination of buttons from the Telephone Keypad
Sadly we are not able to do this remotely
Gareth_L
