on 03-02-2023 10:18
My phone is nowhere near the hub and the hub can't be moved as the computer has to be plugged into it. I was told here that a technician would be able to sort the wiring out but when he came he said he could not do it. Someone on here was looking into this but he has not contacted me since Tuesday. I need to sort this quickly as the phone line will be incoming calls only from Feb 19th. Would someone else here contact me please?
on 03-02-2023 10:39
We had a similar situation.
Consider a cordless phone that has 2 handsets.
The base station connects to the Hub, the second hand set can be located where it is required.
on 03-02-2023 10:46
Hey fowertank,
I'm looking into this, while the other agent is offline and I will send an update over via private message, as soon as I can.
Kind Regards,
Steven_L
