DebiB
Phone won’t ring
Had virgin hub installed with home phone 2 days ago. I can ring out and receive calls but phone won’t ring. There is no ringer off button and I have checked volume is on.
jb66
  • 12.43K
  • 926
  • 1.83K
Re: Phone won’t ring
Is it a really old phone?
DebiB
It is fairly old but it has touch tone keys and I can use it to call out, and I can receive a call. It just won’t ring.
jb66
  • 12.43K
  • 926
  • 1.83K
Some really old phones need a capacitor to ring. Do you have an old adsl filter you can plug into the hub from your old provider to test?
DebiB
Thank you very much for your help - this has now sorted the problem.
I wasn’t hopeful having seen other people raising the same issue but this works perfectly.
Thanks again.
Lisa_CC
  • 4.31K
  • 241
  • 529
Moderator
Moderator
Pleased to hear it's been resolved DebiB following @jb66's advice. Do let us know if you have anymore issues so we can help.
Lisa
