Terry19-70
Phone to Hub4 connection
My landline phone socket isn’t working since I switched from Virgin to BT then immediately back to Virgin. Tried many times by phone and online over last 3 weeks to get Virgin to sort it. I think if I connect the phone to the Hub 4, which is working, that might sort it. But I need an adapter or a cable with a different end at the Hub to do that. What’s the technical name for the adapter or cable? And where do I get one?
stabilo00
  • 247
  • 32
  • 52
Superfast
Re: Phone to Hub4 connection
The lead is RJ11 to RJ11 or you could use a RJ45 to RJ11 adapter. Plenty of both on ebay / amazon
goslow
  • 1.11K
  • 193
  • 353
Knows their stuff
RJ11 plug to BT socket adapter
The VM forum team have arranged for a passing technician to drop one off many times in the past.
Alex_RM
  • 4.3K
  • 247
  • 327
Hi Terry19-70,
Thanks for posting and welcome to  our community 🙂
I'm sorry to hear you've had some issues with the landline, I've been able to locate your account using your forum details and can see you've spoke with an agent, and the phone issue is being looked into.
We'll have it resolved as soon as possible.
Alex_Rm
