Paul_Fletcher
Just joined
Phone not working with new hub - cable needed?
Hi - I got a new router a few weeks ago. Apparently that was needed to handle the upgraded broadband speed I have upgraded to. Since then my phone has not worked and I now realise that I now need to connect the phone directly into the router (correct?). However, I was not sent a cable with the new router and there is no tone at all when I pick up the phone (all the how-to guides seem to indicate I would have been sent one).
Do you know how I get Virgin to send me the connection cable without spending hours on hold on the phone? Or whether there is anything else obvious that I might be doing wrong?
Paul
BenMcr
  • 21.38K
  • 2.32K
  • 4.28K
Re: Phone not working with new hub - cable needed?
A change router for a new broadband speed wouldn't affect how your phone connects. If you had it in a separate line before, that's where it stays. If you had it via the Hub before, you'd continue with that but you'd have an adapter already.
Virgin Media will specifically tell you outside of the install guides if / when they move you from a separate line to the Hub based line. And you'd get an adapter at that point.
Paul_Fletcher
Just joined
That's very helpful - thanks, so with no faults reported in the area I guess I'd have to look elsewhere for a solution?
