on 21-06-2023 10:27
Will my Panasonic KX-TGC220E phone be compatible with virgin fibre?
on 21-06-2023 10:36
Hi there @AimeeY 👋 Welcome to our forum and thanks for your post 😊
We don't have a list of handsets that are compatible with the fibre network.
Sorry that this isn't an answer you wanted, if we can be of any further assistance, please let us know. We're always happy to help.
Nathan
on 21-06-2023 13:19
@AimeeY wrote:Will my Panasonic KX-TGC220E phone be compatible with virgin fibre?
That appears to be a current Panasonic model so you should reasonably expect it to work without any issues.
on 21-06-2023 18:04
Use the original cable that Panasonic supplied and the adaptor the VM will supply & you will be fine.
on 22-06-2023 10:47
I have this phone and changed over yesterday, so far it can make outgoing calls but does not ring with incoming calls.. caller at other end hears phone ringing but nothing here
on 22-06-2023 10:50
@Billm111 wrote:I have this phone and changed over yesterday, so far it can make outgoing calls but does not ring with incoming calls.. caller at other end hears phone ringing but nothing here
Are you using an old phone (early 2000's era or before)?
It may need an adapter with a ringing capacitor in it to make the phone ring
on 22-06-2023 11:22
Hi @Billm111,
I'm so sorry to hear that you're having some trouble with your landline service. Are you able to test a different handset to see if that helps improve matters at all?
on 22-06-2023 16:16
No, phone is about 2 years old and is a Panasonic, with DECT so should work I believe. Obviously rebooted router etc, will give it some time to settle down and try again. Not really a big issue right now as everyone calls my mobile (that I’m interested in speaking to )
on 22-06-2023 16:21
Hi Billm111
Thanks for posting in regards to the recent changes to your landline service and issues experienced, we appreciate you raising this via the forums and welcome to the community.
Depending on when the change completed, it can take up to 24 hours for all of the details and features to update, please let us know after this time if there is still an issue.
Rob
22-06-2023 16:27 - edited 22-06-2023 16:40
@Billm111 wrote:No, phone is about 2 years old and is a Panasonic, with DECT so should work I believe. Obviously rebooted router etc, will give it some time to settle down and try again. Not really a big issue right now as everyone calls my mobile (that I’m interested in speaking to )
Correct, a two year old Panasonic phone should work with no issues. What is the exact model number please?
Some features which might cause this are if the phone is in 'silent mode' or ringer volume turned down or if some kind of 'do not disturb' mode is enabled. These will depend on the phone model as to if they are available and they can sometimes accidentally be switched on when moving the phone about during the switchover.
Edit: When you dial out from your landline to your mobile, is the correct caller ID for your landline number showing up on the mobile?
When you dial in to your landline, does the landline phone register a call is coming in on the caller ID display (just with no ringing sound).
There have been quite a few topics on here recently about VM losing/changing existing phone numbers when customers' lines are switched.
