Haggybear
Message 1 of 7
Phone doesn't ring when called
Hi, my mum switched to Virgin from bt few weeks ago, filled forms in online to keep same number
Now there's is dial tone however when trying to ring the number it rings but the actual landline phone doesn't!
Is this a porting issue?
Tia
Chris_W1
  • 5.81K
  • 250
  • 375
Message 2 of 7
Re: Phone doesn't ring when called
Hi Haggybear, thanks for the message and welcome to the forums. I am sorry to hear the issues which you mum is having, can you confirm if you have tried putting the phone in both the socket in the wall and also the hub and it has been confirm that both have no dial tone as she may be on 21CV via the hub ^Chris
Haggybear
Message 3 of 7
She has dial tone to ring out and when you ring  the number it rings but the actual landline phone doesn't ring
Zak_M
  • 6.12K
  • 315
  • 545
Message 4 of 7
Thank you for coming back to us.
That does sound like it could be a porting issues.
Are you able to pass DPA on your mothers behalf?
Kind regards,
Zak_M
Haggybear
Message 5 of 7
Thanks for reply Zak, I should be able to pass dpa on her behalf
Zak_M
  • 6.12K
  • 315
  • 545
Message 6 of 7
No problem.
I will pop you over a PM so that we can get some account information & we can go from there.
Kind regards,
Zak_M
Haggybear
Message 7 of 7
Tia
Tia
Update: got a new Siemens e390a home phone and problem is sorted
