Alloboy
Phone connection
I have just installed the new Hub 4. The telephone connector does not fit properly. Where can I get another?
BenMcr
  • 21.58K
  • 2.35K
  • 4.36K
Re: Phone connection
Are you a new customer or an existing customer? Do you already have a Virgin Media home phone line?
Alloboy
Existing customer
BenMcr
  • 21.58K
  • 2.35K
  • 4.36K
OK then. When you swap your Hub you don't need to change your phone service unless you're specifically told to do separately to the setup guide.
You can keep using your existing phone connection.
I am aware that the guide may be a little confusing in that respect.
