bluemotorfrog
  • 14
Phone adapter for Hub
I received a letter from VM to say that I won't be able to use my landline phone after March, without an adapter to connect it directly to my broadband hub. I have a very old Philips phone, but it works OK at the moment on the old connection. Would you be able to send me an adapter so I can connect it to my hub after the March deadline?.
Hayley_S
  • 3.9K
  • 129
  • 255
Re: Phone adapter for Hub
Hello @bluemotorfrog,
Welcome back, thanks for posting.
I am sorry for any inconvenience with this.
A work order will be made on the account in March, then you will get sent what is needed for this to work with the Hub.
You do not need to worry about anything with this.
Many thanks,
Hayley
