Jordan7846
Message 1 of 5
Phone Connection
Hi there, I’ve had Virgin for almost 4 years and have only recently decided to set up my landline. Upon buying a phone I found that I don’t have a telephone port installed in my house and the incoming Virgin line doesn’t have one underneath it - so I ordered a BT to RJ11 and plugged it into the router but I’m not getting a dial tone. Have I done something wrong?
FYI, this is the phone I’m using:
https://www.amazon.co.uk/dp/B0787G6S2T/ref=cm_sw_r_cp_apip_dnmKwXiYhN5gR
jb66
  • 12.16K
  • 899
  • 1.76K
Message 2 of 5
Re: Phone Connection
Yes, you need to get the service changed to a 21cv line to use the hub as a phoneline
Jordan7846
Message 3 of 5
Thanks jb66, one quick question - how do I do that? Is it as simple as calling Virgin?
jb66
  • 12.16K
  • 899
  • 1.76K
Message 4 of 5
You can call Virgin to report a fault, they will send a technician to fix your old line, the technician may offer to convert your line to the new style rather than installing a socket as its easier
Jordan7846
Message 5 of 5
Brilliant, thank you!
