Emma_xo
Message 1 of 7
No ringtone for incoming calls
I have just switched from BT to Virgin, installation was 2nd September, everything is working fine apart from the phone, we receive incoming calls, however we have no way of knowing when a call is being received as the phone no longer rings, we have tried a number of phones of different models and they are all the same.. HELP.
Also the dial tone seems to have a weird blip in it since today.  Not sure what that is.
Is anyone able to assist with this problem at all.
Thanks in advance.
dowie
  • 30
  • 13
Message 2 of 7
Re: No ringtone for incoming calls
Hello,
Firstly the Blip in your dial tone means you have a Voice message on Virgin voice mail which is on 1571.
Secondly it sounds like there is a problem with the master socket if you have any extensions plugged in, unplug them try ring it with just a 1 phone plugged in. If it rings you have a wiring fault on the extensions. If it doesnt ring give Virgin a call and book an Engineer.
Hope this helps
Dowie
dowie
  • 30
  • 13
Message 3 of 7
Did you get it sorted??
Emma_xo
Message 4 of 7
I’ve got an engineer coming round tomorrow so fingers crossed.
Roger_Gooner
  • 6.72K
  • 490
  • 1.18K
Legend
Message 5 of 7
Old handsets require a ring capacitor for the ringing sound but this is missing from the RJ11 to BT adapter provided by VM. So, either buy this adapter with a ring capacitor (costs £4 on eBay) or use a modern handset.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
AlliAmoux
Message 6 of 7
What you mean by ringtone. You need to download the free ringtone to your phone device to see if it works again. I'll help you
Sonnerie telephone portable gratuite: Sonnerie telephone
GuillermoCarpe
Just joined
Message 7 of 7
Hi, this is a great article. Besides, you can also download quality ringtones at  http://klingeltonmobi.de  it contains all the best songs 2021
