No out going calls
duluxs
I have only just found out that my land line has no dial tone and you cannot make outgoing calls.
If someone calls my number they get the ringing tone as though it is working.
finally a family member rang my mobile, and told me what's going on, that's how I found out the land line is US.
although the service status says there no problem in my area.
"If I had the power of great unlimit, I'd stop the world, put it right, then respin it"
1 ACCEPTED SOLUTION
Accepted Solutions
Reece_MH
Hi @duluxs,
Thanks for your post. I'm sorry to hear that you're having issues with receiving and making calls on your landline. I've ran some checks on our end, and I can see that there is currently an outage on your service, which may be causing issues with the Broadband, TV and Landline services.
The reference for this fault is F009956593 and is due to be resolved by 19th July at 14:55. I apologise for any inconvenience.
Regards,
Reece - Forum Team
New around here? To find out more about the Community check out our FAQ
1 REPLY 1
Reece_MH
Hi @duluxs,
Regards,
Reece - Forum Team
