on 09-12-2022 11:42
We have been sent our dongle for the landline but get neither a tone through our old wall box or through the new dongle. Although we've had the dongle for a few weeks now we haven't been told to switch so the change may not have been made. Can I find out when our switch over will be and/or do I need an engineer to fix the wall box?
Matt
on 09-12-2022 11:55
Hi skyjackers,
Thanks for raising your query and welcome back to the community.
Apologies for all the confusion with this, so we can investigate it further I've dropped you a PM.
The message will appear within the purple envelope icon.
Regards,
on 09-12-2022 12:05
Thank you Kain.
on 09-12-2022 12:07
No problem,
The message should now be in your inbox.
on 09-12-2022 15:59
Thanks for your cooperation over PM skyjackers,
I'm glad the reboot resolved the matter after the switch.
Do pop up if you have any further queries.
All the best,
