Pastorey
Landline work for Dial up connection
does the phone socket in the hub support dial up connection we have an Dial up cash machine using the system that is struggling to communicate with the supplier
Alex_RM
  • 4.29K
  • 247
  • 327
Re: Landline work for Dial up connection
Hi Pastorey,
Thanks for posting and welcome to our community :
It's a cable modem not DSL so you would be unable to use dial up.
Can you please elaborate on what you mean?
Alex_Rm
nodrogd
  • 16.45K
  • 1.92K
  • 3.93K
The OP is using a dial up analogue device not an internet modem. These lines should support Fax machines & Credit Card readers, the latter of which I think is what the OP is trying to use
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
Pastorey
So it's a 56k modem that just needs a standard phone line to dial a host to receive fax/internet tone the supplier needs to send a download to it but the machine keeps dropping equipment a new modem and software load has been done on the machine and we are still seeing issues however we have never run a machine through a virgin fibre hub before
Laurie_C
  • 395
  • 18
  • 41
Hi Pastorey,
Thanks for getting back to us. I'm afraid that we can't really comment on third-party equipment. However, if the machine is designed to work with a standard phone line, it is unlikely that it would be fully compatible with our Hub.
Kind regards,
Laurie
Laurie_C
Roger_Gooner
  • 6.53K
  • 472
  • 1.14K
Legend
In theory the ATA built into the hub should enable your cash machine dialing to work, but if analogue dial-up is not the way forward look instead for an IP-based or wireless solution.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
