  • 5
AlbertoS
Landline phone not working, constant sound
My landline phone has not worked for a while, now I am realising that is a waste to pay for a service that does not exist.
The problem is a constant sound in the line. I have called the landline from my mobile and I can hear it ringing. If I call from the landline to my mobile this does not ring. In any case from the landline you cannot hear anything, just the constant sound.
I have no idea what is wrong. Any help in solving this would be appreciated. Thank you in advance.
  • 9.22K
  • 381
  • 631
Forum Team (Retired) Collette_O
Re: Landline phone not working, constant sound
Hi AlbertoS,
I am sorry to hear that you're having some troubles with the landline service.  I have carried out some checks with the line and no fault has been detected.  I would like to arrange for an engineer to call round and fix this for you.  I will send some details in a private message.  Look for the purple envelope icon above.
Collette.
