Landline connected through hub
oldieme
After problems with my landline it was connected through my hub. This now means I have no phone if there is a power cut.  Is there a way I can make an emergency call during a power cut?
1 REPLY 1
Tom_W1
Hi @oldieme thanks for your post although I'm sorry you're having issues with your landline.
Can you advise on what problems you're having with your landline at the moment, as all appears active from our side at the moment with no outages?
If there is a power cut, then unfortunately your Hub will fail and this does mean your landline will too. Do you have a mobile device that you could make calls with in an emergency just in case?
Many thanks
Tom_W
