Landline - No incoming calls
JJ16
A common problem by the looks of things and as a day old VM user, I have this issue.
Modern DECT phone Ren 1, connected to HUB 5 via an adaptor. Outgoing calls possible, but not able to receive incoming calls. All connections checked, HUB rebooted and a call into the Helpline and it's still not working!
Helpline said I needed to get a VOIP phone, but I'm not sure this is the way to go. I don't want to buy another handset (have tried 2 modern cordless phones already) and find this is not the fix. Help please?
9 REPLIES 9
Megan_L
Hi JJ16,
Thanks for using the Community Forums to get this issue with your landline looked into, I am sorry if this has been causing some frustration 😥 I would be more than happy to look into this for you!
Can I ask what happens when you or other people try to call your landline please?
Also, if you're a new customer, can I ask if you've ported your number over to us from another provider?
Thanks!
Megan_L
Hi Megan
The caller does get a ringing tone, but nothing happens on the handset. My number has been ported from my previous supplier
Thanks JJ16,
It could be an issue with the porting process, could I ask how long ago you were fully installed please?
I also have a helpful link here which has information specifically on not being able to call into your landline 👉 Landline Fault Fixes
Could you please take a look and let me know if anything rectifies the issue please?
Megan_L
Hi Megan
TV, BB and Home phone was installed this morning. 8 hours ago
Thanks JJ16,
Your landline may still be getting set up on our side in that case, but please let us know whether any of the information in the link helps to resolve the issue.
I'll still be here to help if not 🤗
Megan_L
Hi Megan
Thanks for the link, but nothing there I’ve tried resolves the issue
No worries, thanks for sticking with me there JJ16!
I'll get a private message sent over to you now so we can take a closer look into this!
Speak to you soon.
Megan_L
JJ16
Thanks Megan
Chris_W1
Hi JJ16, I am glad to see that things have now been resolved and let us know if you require any further assistance? - Chris.
