Zeiss
Message 1 of 7
Land line not working no ring tone or incoming calls
All suggested tests done ie, tried new phone,tried unplugging and plugging phone at wall socket,had this problem a couple of times the past,only solved when engineer checked connection in the main box on the street. What I really require is an engineer appointment urgently,please could someone arrange this at your end please.
Many Thanks
Hayley_S
  • 3.9K
  • 129
  • 255
Message 2 of 7
Re: Land line not working no ring tone or incoming calls
Hello @Zeiss,
Welcome! Thanks for posting.
I am sorry that your landline is not working for you.
I located your account using your forums details, I can not see any issues with your line. Have you tried using a different handset?
Many thanks,
Hayley
Zeiss
Message 3 of 7
Hi Hayley.
Yes I have used new handset in the vm wall socket,still doesn't work,just gives message check line,so I have checked all cables,and connections.
As I said in the previous post an engineer fixed the problem and on two previous occasions it was the connection in the main cable box in the street that had been disconnected.
Hayley_S
  • 3.9K
  • 129
  • 255
Message 4 of 7
Thank you @Zeiss,
I will send you a private message now, please look out for a plum envelope at the top right of your screen.
Many thanks,
Hayley
Hayley_S
  • 3.9K
  • 129
  • 255
Message 5 of 7
Thank you for talking to me in a private message @Zeiss,
I have booked an engineer appointment for you now, please check you online account to see the date and time of this appointment, this was the earliest date and time I could book for you.
I hope this is okay, let me know if not.
Many thanks,
Hayley
Zeiss
Message 6 of 7
Hi Hayley.
That's fine.
Thank you for your help.
Hayley_S
  • 3.9K
  • 129
  • 255
Message 7 of 7
You are welcome @Zeiss 🙂
Have a lovely rest of the day.
Hayley
