TKG53
  • 14
Keep same landline number
     Where should I request to keep my same number.I am moving home and I want to transfer Virgin to virgin.
Thank you.
DJ_Shadow1966
  • 6.84K
  • 1.31K
  • 1.88K
Re: Keep same landline number
Hello
When you do a move home as long as you are in the same area code then the port happens automatically as part of the moving home process.
Regards Mike
Tom_F
  • 2.98K
  • 173
  • 367
Hi TKG53, thanks for getting in touch - apologies for the delayed response here.
Further to Mike's advice above - let your old provider know you want to keep the number as the line will need to remain active for the port-in to complete from our side.
If you have any further queries or if there's anything else we can help with please don't hesitate to get back in touch.
Tom
