Issues with incoming calls on Landline
SuperHighway
Up to speed
Experiencing issues this morning with incoming calls. Call either disconnects or no sound.
outgoing calls connect fine. Phone is via the super hub.
1 ACCEPTED SOLUTION
Accepted Solutions
Hi all, just returning to update the thread.
I have responded to your PM Superhighway, apologies for the delay!
Just a friendly reminder that our community forum is not an instant response service, if you ever need instant support please give us a call on 0345 454 1111 or 150 from a VM landline. Text us on +44753 305 1809, and WhatsApp us on +447305 327 112.
Thank you for your patience whilst we get this sorted!
I will return with another update when possible.
All the best.
Molly
7 REPLIES 7
Molly_T
Hi SuperHighway, welcome back to the community! Thank you for posting.
Sorry to hear of this issue with incoming calls on your landline - how long has this been going on for?
Are the calls disconnecting upon answering or before you are able to answer?
I will send you a PM to confirm a few account details so we can investigate and get a technician booked out to you if needed.
Thank you! All the best.
Molly
Hi Molly,
they’re disconnecting on answering. Got your PM too and will reply shortly.
thanks
Hi Molly,
responded to your PM but no further contact.
The fault is still there.
Which hub do you have? If it's Hub 5 there's a known issue that started from around Friday 25th - https://community.virginmedia.com/t5/Home-Phone/INCOMING-CALLS-CUT-OFF-WHEN-ANSWERING/m-p/5191259/hi...
Yes it’s the hub5. Begs the question why not put this on the status page!
Looks like a fix has been applied but required a reboot for it to kick in.
All the best.
Molly
