on 12-12-2022 11:14
Incoming calls to my Virgin Media landline go to voicemail after just one ring.
If I'm beside the phone and pick it up straight away, the call is connected, but usually I can't answer in time.
This started about a month ago. Before that, voicemail worked exactly as it was supposed to (for many years). To the best of my knowledge, I have not changed anything that would affect voicemail operation.
on 12-12-2022 11:57
Hi hslavin,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issue with your landline.
Have you been able to try a different handset?
^Martin
on 17-12-2022 11:50
Yes, I have tried a different handset.
I still have the same problem (incoming calls go to voicemail after just one ring)..
on 17-12-2022 12:00
Hey hslavin,
Welcome back to the community and thanks for taking the time to post.
I’m sorry to hear of the issues that you’re having with your landline at the moment, do you have voicemail built into your handset or are you just using the Virgin Media voicemail service?
Kind Regards,
Steven_L
on 17-12-2022 15:18
I use Virgin Media voicemail (1571 to retrieve messages from the switch).
on 17-12-2022 15:30
Thanks for coming back to me hslavin, I have looked into this and have passed the issue onto our 2nd line faults team, who will get in touch with you directly in the next 24 to 48 hours to discuss your issues further.
Kind Regards,
Steven_L
on 20-12-2022 11:01
Thanks to Steven_L for referring this to Virgin Media support, and thanks to Virgin Media support for their attempts to contact me by phone. Unfortunately, I was unable to take either of the calls to my mobile, and the two calls to my landline went to voicemail before I could answer. I look forward to a subsequent call attempt being successful.
on 20-12-2022 11:10
Hey hslavin, thank you for reaching out and I am sorry you have missed the call.
I have sent a message to the agent dealing with matter to give you another call when they can.
Please do keep me updated on this. Thanks
Matt - Forum Team
New around here?
