on 10-10-2015 17:02
I've booked an engineer for next week but thought I'd ask here in case anyone could help.
I had a landline installed last week. This was actually a reactivation of an existing line in my flat. Not sure when the Virgin line was last used, but it's an old NTL socket. For the past three years I've been using a BT line.
I had a cordless phone which always worked without a problem on the BT line.
When the engineer connected the Virgin line, he tried calling my phone and the ring was odd. It sounded like there wasn't enough power, the rings weren't fully ringing and there were silent gaps. The engineer said he thought it was my phone as he said the line was fine.
So I went and bought another phone, and it's not ringing at all. When I do 1471 there is a record of the call, but in the handset call log there is not.
Going back to my old phone, it does ring but it's still a "weak" ring.
I took the new phone next door and it worked ok on the neighbour's BT line.
Outgoing calls are not a problem.
I've done a line test online and it came back fine.
Any suggestions I can try while waiting for the engineer would be appreciated.
Annoying that I bought a new phone when it looks like the problem is actually with the line...
on 11-08-2017 23:05
For months I have been experiencing problems with my Virginmedia landline. Always told line is fine yet I have no dialling tone OR callers get Busy Tone. After umpteen visits from engineers who give different excuses for my problems I have had a dialling tone so can make outgoing calls. Discovered that the phone does not ring for incoming calls and hospital appointments are getting missed, which is critical what with the current state of the NHS. I have even bought a new phone as previous engineers suggested the phone is faulty....problem persists. I have a cordless phone also and hope to test it at my neighbour's home within the next 24 hours. I had a BT socket prior to the installation of the VM one when I took their package. Today, 11 Aug 2017 I have discovered that both sockets give me a dialling tone!! Not sure if this is normal. It is so frustrating that am losing sleep over the whole issue. Reading comments on this Forum helps as I realise mine is not an isolated case.
on 15-08-2017 09:09
Hi VMLAD
Welcome to the Community, I'm so sorry to learn about the problems you're experiencing with your telephone service recently.
I'd like to take a closer look at this from our end but I've not been able to accurately locate your account using your forum information unfortunately. So I can do that, could you respond to the private message I've sent with the requested information? You can view the message by clicking the envelope on the top right of this page.
Look forward to hearing from you
Craig
on 19-12-2017 16:58
on 20-12-2017 08:20
Hi DR1967
I just wanted to let you know that I've responded to your thread regarding this issue, which you can view by [clicking here].
We'll talk soon
Craig
on 08-05-2018 10:43
I am having the same issue. Phone doesn't ring for incoming calls. Outgoing calls are fine.
Tested with multiple handsets but still the phone is not ringing and in some cases no dial-tone also. The current handset I have works on all other BT lines. so clearly not the fault of the handset.
Appreciate any help.
Thanks.
on 09-05-2018 09:25
Hi DRUB9,
Welcome to the community.
I am sorry to hear that you're unable to receive calls.
I have carried out some checks with the line remotely and all is looking ok from here so far. Can you please power off/on the hub and let me know if this helps?
I'm here to help further if you need me.
Collette.
on 09-05-2018 10:51
on 09-05-2018 11:05
Hi DRUB9,
Thanks for carrying that check out for me. It helps to rule out a few things so that's super.
I will arrange for an engineer to call round for you. All the details will be in a private message, look for the purple envelope icon above.
Collette.
on 09-05-2018 11:10
Thank you. I am awaiting for an engineer to arrange a visit.
thanks.
on 17-05-2018 10:45
Hi All,
I am posting this for the benefit of future customers.
Today an engineer found out that not all phones are compatible with Virgin Media phones. I checked about 4 phones which were working find with BT lines but failed on Virgin Media - eg- not ringing or no dial tone. The reason were
1. the phone was not compatible and/or
2. The cable leading from the phone to the router was not compatible.
Suggest changing all and checking different combinations till it works.
The engineer (Abdul) who visited twice was really good and special thanks to him as he was proactive and was not hasty to blame it on the handset being faulty.
- Dinesh
