on 27-11-2022 20:24
Incoming calls cut out immediately on answering. Been on the phone twice to tech help, even kicked up to second line support- still can receive incoming calls.
on 27-11-2022 20:25
Still “cant” receive incoming calls.
27-11-2022 21:44 - edited 27-11-2022 21:45
It is a known fault.
Are you using HUB 5?
on 27-11-2022 21:47
Yes, the newest one.
on 27-11-2022 22:04
on 27-11-2022 22:15
Is this a forced software update or one I need to do myself?
on 27-11-2022 22:19
YOUR GUESS...... IS AS GOOD AS MINE..????
on 28-11-2022 08:16
Hi shamus5178,
Thank you for reaching out to us in our community and welcome back, sorry to hear your incoming calls drop and for any inconvenience this has caused, I was able toi, locate you on our system with the details we have for you and can see you have spoken to us and a technician has been arranged, if you do need any further help in the meantime please reach back out.
Paul.
on 28-11-2022 09:42
Thanks Paul, from reading the other forum post, seems like the issue is with the hub 5 - any resolution date on this please?
on 28-11-2022 09:46
Hi shamus5178,
Thanks for coming back, I was able to get some further information and can advise this is part of a fault and an internal ticket has been raised and we are working on a fix ASAP, apologies again for any inconvenience caused.
Paul.
