My hub has had a red light for weeks
Searching the site, it states it is due to overheating
I have cleared everything around it and now sits pretty much by itself but the router stayed red
Doesn't feel hot to touch and cannot work out how to stop it being red.
The website BOT takes you around and around in circles
As Internet was still usable, i carried on. But now the light is off
The WiFi light is on only
Switched it off and on and the red light blinked for a bit and then turned off
No idea what I can do
