on 15-12-2022 13:04
on 15-12-2022 13:31
Hi ViperSP,
Thanks for your post and questions regarding the new Hub 5.
It's worth noting that the Hub 5 is not ipv6. It offers WiFi6 which is something different. This is the latest generation of WiFi technology and takes advantage of dual band reach for guaranteed speed, coverage and reliability and less WiFi lag.
The hub is currently only available to those customers upgrading to the 1GB service due to stock levels.
If you would like to upgrade then please speak to the team on 150 / 0345 454 1111 so they can go through your options with you.
Let us know how you get on.
on 15-12-2022 13:41
i already have gig fiber ive had it for just under 8 months 🙂
on 15-12-2022 13:46
VM as a whole, simply do not support IPv6 in any way - currently. It has been promised as 'being worked on' etc. but that's been the case for about a decade.
on 15-12-2022 13:52
VM do have ipv6 on the line but it functions as a tunnel to ipv4.
i was curious to know if it was fully implemented yet with the hub 5 as the rumors were circulating it fully supported ipv6 when it was new back in January/February 2022.
since i have gig fiber already will i be able to get the hub 5 please?
on 15-12-2022 14:29
Hi @ViperSP
I can see that my colleague has already responded and answered your questions regarding the HUB 5.
Please let us know if you are having any further issues or have any questions at all. We'll be here to help on the community forums if needed :).
on 29-03-2023 21:13
On my Hub 5 I have IPv6 options as well as WiFi AX(6)
