rharding
Message 1 of 9
Hub 4 telephony disabled
Trying to use landline plugged into Hub 4 directly rather than a wall socket, but the settings on Hub 4 says telephony disabled. Spent over an hour on phone getting nowhere as none of the agents actually understood the basic problem. They just kept asking me to use another piece of equipment or get the provider of the phone handset to sort the issue out! How can this setting be enabled?
Anonymous
Not applicable
Message 2 of 9
Re: Hub 4 telephony disabled
if your provisioned with a POTS line you need to keep using that for now.
VM are slowly switching everyone over but mostly for new customers right now
Why do you want to change?
rharding
Message 3 of 9
The wall socket in the office is damaged, so I thought it would be easy to use the Hub 4 instead!
Ashleigh_C
  • 595
  • 23
  • 50
Message 4 of 9
Hi @rharding
Thank you so much for your first post to our Community Forums and Welcome! It's great to have you on the team!
I am so sorry for the confusion with your phone line but I can confirm @Anonymous is correct and if your phone line is still a traditional phone line it would need to be changed to our 21CV phone to be able to work from the Hub.
Can I ask how the wall socket has been damaged and is your phone service currently down? Thank you.
Ash_C
Anonymous
Not applicable
Message 5 of 9
also is the socket in the office the master socket or is it an extention?
rharding
Message 6 of 9
Hi, how do I tell which phone line I have? I have been with Virgin for years.
The office socket is an extension and the cable to it has been damaged and can't be repaired. The master socket works fine.
Alex_RM
  • 4.28K
  • 247
  • 325
Message 7 of 9
Hi rharding,
Thanks for getting back to us,
If you have an issue with an extension after it being installed for 12 months or longer, this would be a £99 charge for an engineer to resolve this.
If you'd like me to arrange this let me know and I can pop you over a private message.
Alex_Rm
rharding
Message 8 of 9
It's not an issue with an extension, I wish to plug into the Hub 4 but it says telephony disabled.
BenMcr
  • 21.44K
  • 2.34K
  • 4.3K
Message 9 of 9
You can't yet choose to change how your phone is delivered. If you have a working line separate from your Hub, that's what you need to use.
At some point in the future Virgin Media will offer a swap to the Hub lines for all customers as they will want to decommission the physical phone system, but that's not now.
Apart from the physical connection, the two phone lines work in the same way. There is nothing extra a phone line through the Hub will give you currently over the separate one.
