RobF2020
  • 7
Message 1 of 20
Hub 4 Upgrade - Telephony Disabled
like many others I upgraded to hub 4 from hub 3 in order to get gig1 fibre but now the landline doesnt work . i have logged into the router and under router status its saying "Telephony Disabled" please can someone help with this. thank you .
i will add i have rebooted 3 times over the last day. last one 5 mins ago 08:17am. and still no landline. all cables plugged in and crrectly. and handset does work. still saying disabled on router screen.
thanks
rob
Tags (2)
Daveg14
  • 94
  • 7
  • 5
Up to speed
Message 2 of 20
Re: Hub 4 Upgrade - Telephony Disabled
Rob
Did you get your phone through your old  super hub 3 plugged into it  as most phones don't use the hubs they are separate
David
RobF2020
  • 7
Message 3 of 20
Hi David,
my phone was plugged into the previous hub without any problems at all.
Cheers
DJ_Shadow1966
  • 7.11K
  • 1.36K
  • 2.01K
Message 4 of 20
Hello
It can take 24hrs for the hub replacement to be actiivated for telephone, if it more than 24hrs please get back on this thread and I will escalate to a VM forum staff member to look into it.
Regards Mike
RobF2020
  • 7
Message 5 of 20
Hi Mike,
Thanks for this much appreciated.
Will keep you updated!
cheers
rob
RobF2020
  • 7
Message 6 of 20
Hi Mike,
the landline is still not working - could you please escalate the issue?
thanks!
rob
Alex_RM
  • 4.48K
  • 258
  • 341
Message 7 of 20
Hi RobF2020,
I'm sorry to hear you're still having an issue with the line, I can see this is being investigated by our second line team currently.
I've popped you over a private message to get a few more details from you and give an alternative contact number incase they need to contact you  🙂
Alex_Rm
RobF2020
  • 7
Message 8 of 20
Hi Alex,
Thanks for this. I couldn't see your PM - can you resend please?
Thanks!
Rob 🙂
Alex_RM
  • 4.48K
  • 258
  • 341
Message 9 of 20
Hi Rob,
Thanks for sending your details over 🙂
I've updated everything, and the 2nd line team will contact you if needed asap
Thankyou,
Alex_Rm
RobF2020
  • 7
Message 10 of 20
Thats great - thank you Alex much appreciated 🙂
