DaveinBeds
  • 13
Message 1 of 29
Hub 3 "Telephony(Disabled)"
Hub 3 says "Telephony(Disabled)" When I try to connect a phone. Yes, I am using a RJ11 Plug to BT Socket
jb66
  • 12.28K
  • 912
  • 1.79K
Message 2 of 29
Re: Hub 3 "Telephony(Disabled)"
Is the phoneline via your hub part of your package?
nodrogd
  • 16.82K
  • 1.97K
  • 4.09K
Message 3 of 29
It will say this if your Landline is currently provided via a seperate BT type socket on your wall. These sockets are not for general VoIP. These are exclusively for the next generation Virgin phone system that is gradually being rolled out.
VM BB TV Landline PAYG mobile. Freeview/Freesat HD, Tesco Mobile. Customer since 1993
DaveinBeds
  • 13
Message 4 of 29
Hmm, explains a lot.
Does seem odd that they tell you just to plug it in and even checked the area I was in.
Thank you for your assistance.
Roger_Gooner
  • 6.75K
  • 490
  • 1.19K
Legend
Message 5 of 29
The only customers who get the phone from their hub are new customers and those who have moved house.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
DaveinBeds
  • 13
Message 6 of 29
So, would it not make sense that when I log into VM and put in my postcode they could not tell me that as I have been a customer for 18 years, I cannot have it?
I moved to a new house 12 years ago, so my cable has not been touched in all that time.
Long standing customers seem to be limping along with outdated cables and modems and new customers get all the shiny stuff.
I just had to spend about £100 on a TP link deco m4 mesh system to improve the Wi-Fi as my Ring doorbell chime would come up as poor signal. It was plugged in eight feet from the hub 3. We would lose the Wi-Fi signal all together throughout the day.
I spent two weeks trying to phone VM and never got to speak to anyone. Why is there no system for calling customers back?
I tried the text system, but have never had a reply. I even lodged a compaint through there online complaints system and they never replied.
Why?
Tags (2)
BenMcr
  • 21.6K
  • 2.35K
  • 4.36K
Message 7 of 29
Where did you see that instructions to plug it in?
The coax cable and modems are the same in existing cabled areas whether you have a separate landline or a Hub based line. The difference is that recently Virgin Media stopped selling the separate landlines even where there is cable for it. All new customers get a landline through a Hub.
Some existing customers have already been moved over as well and all customers eventually will be moved to the Hub based lines. But if your an existing customer with a separate landline Virgin Media will let you know when you have to do that.
DaveinBeds
  • 13
Message 8 of 29
You asked, "Where did you see that instructions to plug it in?"
Due to my Hub 3 not working properly I was sent another hub.
Although the "new" hub I was sent was second hand it did come with instructions.
The instructions were also available online on the VM web site.
https://my.virginmedia.com/content/dam/virgoBrowse/docs/Virgin-TV-V6-QuickStart-Guide-for-New-Custom...
Zak_M
  • 4.45K
  • 259
  • 421
Message 9 of 29
Good morning @DaveinBeds
The link you have provided is regarding new customer set up.
Are you still having issues with your landline?
Kind regards,
Zak_M
DaveinBeds
  • 13
Message 10 of 29
My landline is fine.
I just fancied having it go through the Hub 3.
